Firmware
Tip
Most users do not need to compile their own firmware. Pre-built firmware can be downloaded from GitHub.
Updating firmware
emonPi3
Web Interface
The easiest way to update the emonPi3’s firmware is to use the firmware upload tool.
  1. In your local emonPi3 web interface, navigate to Setup > Admin > Update > Firmware.
  2. Select serial port ttyS0 and then select emonPi3 from hardware.
Command Line
To update the emonPi3 using the command line, you can use the BOSSA application. The following steps are taken:
  • Open a serial connection using, for example, minicom to /dev/ttyS0 (minicom -D /dev/ttyS0 -b 115200)
  • Enter ‘e’ and then press Enter.
  • You will be prompted to reboot to enter the bootloader. Any unsaved configuration changes at this point will be lost. Press ‘y’ to continue, or any other key to cancel.
  • The emonPi3’s LED will slowly pulse green indicating it is in the bootloader.
  • To check the bootloader is responsive, run bossac -p /dev/ttyS0 -i.
  • To upload the compiled firmare, run bossac -p /dev/ttyS0 -e -w -v -R --offset=0x2000 path/to/bin.
  • If BOSSA is not installed, it can be installed by:
  • git clone https://github.com/shumatech/BOSSA
  • cd BOSSA
  • make bossac
emonTx6
To update the emonTx6’s firmware, the following steps are taken:
  • Connect a USB cable to the emonTx6’s USB-C socket.
  • Open a serial connection using, for example, minicom (e.g. minicom -D /dev/ttyACM0 -b 115200) or the Arduino serial monitor.
  • The emonTx6’s LED will slowly pulse red and a drive called EMONBOOT will appear in the file manager.
  • Drag and drop the firmware image ending .uf2 to the EMONBOOT folder.
  • The emonTx6 will reboot and enter the application.
Development
Contributions are welcome. Small PRs can be accepted at any time. Please get in touch before making large changes to see if it’s going to fit. This is an open source project, so PRs and issues may not be addressed quickly. This is not a comment on the quality of the contribution, and you are free to fork the project at any point.
Tip
Run the install-hooks.sh script to enable the pre-commit hooks, which include autoformatting. A clang-format pattern is included. You may need to install clang-format and ruff using your OS’s package manager.
How to compile firmware
There is a single unified firmware for the emonPi3 and emonTx6. The firmware is self contained, with no external libraries required and does not require any frameworks like Arduino or Platform.io.
Compiling the firmware requires the the Arm gcc toolchain. This also may be available as a package in your distribution. The Makefile is for Arm Cortex-M0+ based microcontrollers, specifically the Microchip ATSAMD21J17 (datasheet, errata).
Ensure the toolchain is available on the path by running:
Clone the emon32-fw repo and compile the firmware:
Images in .bin, .hex, .elf, and .uf2 formats will be in the bin/ folder. The image names include the version and the git commit hash for traceability.
Flash and debug
The emonPi3/Tx6 exposes a standard Arm Cortex-M 10-pin SWD connector. You can flash and debug the microcontroller using a CMSIS-DAP compatible debugger using openocd and arm-none-eabi-gdb. There is no requirement to use the vendor IDE and tools.
