EmonCMS - custom dimension of the Dashboard surface
Hi All,
I'm searching for a way to change the default scale of the Dashboard zone.
Indeed, I would like to enlarge the "editable" zone, and also fix a different default height, to avoid to play with tricky element's moves to gain place at the bottom of it....
The purpose is to use almost 100% of my screen view and to keep normal  resolution  (not a  "zoom-in" with the browser)
Thanks.
XaroRSA's picture
Re: EmonCMS - custom dimension of the Dashboard surface
In dashboard_edit_view.php, after the <script type="application/javascript"> line, add the following:
$(".container").css("width","100%");
That just took 2 hours of hunting, you are welcome :D
Ok wait seems in dashboard view it doesnt work hold plz
Ok add the line mentioned above after the <script type="application/javascript"> line in both the dashboard_edit_view.php and dashboard_view.php file.
bugmax's picture
Terrific !
That's working fine.
Thanks a lot XaroRSA !
XaroRSA's picture
Will work for food :D
Does this fix extend the header to 100% width, to overcome the problem seen on my phone's screenprint below.
XaroRSA's picture
I think it will Paul
That's good, it's been an annoyance of mine for a long time!
Have you done a Git pull request, it's worth an update.
bugmax's picture
Unfortunatly, It's not working.
I've just did the test on my Iphone.
First the 100% don't apply to my Iphone Display.
Everything you've put on the Dashboard editor will be displayed, but you will have to zoom out
and the picture won't stay more reduced as much as you probably need. That's point is maybe for Iphone only.
The navigation bar behavior is not the same as the dashboard editing zone, so it stay exactly the same as you picture...
Regards.
XaroRSA's picture
Can you post a picture bugmax
