Uncaught exception 'RedisException' (problem solved)
Dear Sirs
I am new to emoncms with a fresh copy installed on a Windows 7 32-bit laptop.
My server configuration details is:
Apache v2.2.22
PHP v5.3.13
MySQL v5.5.24
redis was manually loaded after installation of wamp with php_redis.dll download from https://github.com/nicolasff/phpredis/downloads.
In php.ini add
extension=php_redis.dll
restarted wamp.
After finishing create a MYSQL database (step 4 of Windows Installation), emoncms database is now visible in phpmyadmin.
A new user with user name "john", password "123456", "localhost", and "emoncms" added to settings.php.
These data are copied to settings.php in emoncms folder.
$default_engine = Engine::MYSQL;
Then I open emoncms with http://localhost/emoncms with error message below.
(!) Fatal error: Uncaught exception 'RedisException' with message 'Can't connect to 127.0.0.1:6379' in C:\wamp\www\emoncms\index.php on line 35
(!) RedisException: Can't connect to 127.0.0.1:6379 in C:\wamp\www\emoncms\index.php on line 35.
Could anyone advise how to tackle this problem?
Best Regards
John Leung
techtoys's picture
Re: Uncaught exception 'RedisException' (problem solved)
It turns out the error 'Can't connect to 127.0.0.1:6379' was due to the reason that Redis-server was not installed and started.
Google Redis for Windows and install, restart the PC.
Under Windows Services make sure Redis Server has been started.
http://localhost/emoncms/ is now working.
