emonCMS API : send bulk mode but with the possibility to add names like in json={power:200}
Hi.
To send data to emonCMS, I'm using the bulk mode, as defined in /emoncms/input/api:
/emoncms/input/bulk.json?data=[[0,10,250,100,20],[2,12,1437,3164],[10,10,252,80,21]]
This allows me to buffer a few samples and send them in one shot.
There is another sending format:
/emoncms/input/post.json?json={power:200}
but AFAIU it does not allow to send several samples from different time. Is this correct ?
Is there a format I could use to combine both advantages (multiple time samples and nice input name) ?
nubble's picture
Re: emonCMS API : send bulk mode but with the possibility to add names like in json={power:200}
I too need this functionality so that I may do something like:
/emoncms/input/bulk.json?data=[power:[0,10,250], pf:[10,10,2],power:[10,10,2]]
The wireless node ID is the only way current to differentiate between individual input data items, but this does not help if I want to use just a single wireless node [node 0] with many input items in it. Id like to bulk post to the individual input items such as power and pf within node 0.
Thanks in advance.
jamieg's picture
Bit of an old thread this but any chance this will ever be possible:
/emoncms/input/bulk.json?data=[power:[0,1,250], temp:[0,1,22],power:[60,1,300],temp:[60,1,23]]
I want to use bulk mode but need to also send names.
Thanks in advance
firefox7518's picture
Would love that feature too!
