Loss of feeds to EmonPi from EmonTx after update to 2.6
https://openenergymonitor.org/emon/node/12329 covers previous dropped connections under earlier versions.  2.5 was stable but the Emoncms menus were corrupt for the Apps drop down.  I was living with that, then decided to try an update tonight to see if that solved it. Well, it cured the menu, but the feeds from the EmonTx are completely gone and the node (7) is shown as inactive.  I have rebooted the Pi.  If I reboot the EmonTx, I will get a momentary single feed update on the Pi EmonCMS webpage, then immediately revert to nothing although node 7 is then shown as "x minutes ago"
Please can someone explain how to go back to 2.5?
Thanks,
Andy
AndyS's picture
Re: Loss of feeds to EmonPi from EmonTx after update to 2.6
OK found this post which gave me the required backout: https://openenergymonitor.org/emon/node/12188
back at 2.5 and all running again.
Goes to show I should never break rule 1 (If it ain't broke, don't fix it).
Andy
