How to program the WiFi MQTT Relay with FTDI?
Hi!!!
I am using a translator, sorry.
I purchased this product. I will charge it the firmware by FTDI , but not how.
Does anyone have a manual step by step?
thank you.
pychu's picture
Re: How to program the WiFi MQTT Relay with FTDI?
Hi. I used "NODEMCU" program to charge the oem.v2088.bin firmware. and Wifi MQTT Relay stopped working.
I Used this parameter.
Baudrate 460800
Flash Size 16MByte
Flash speed 80Mhz
SPI Mode QIO
memory direccion 0x10000
some help?
