CSV export problems - Request datapoint limit reached (8928)
Hi im running version | 9.3 | 2016.01.26.
I can export one days worth of data fine (samples every 10s) but when trying to export 2-3 days worth of data in one hit i get the message
{"success":false,"message":"Request datapoint limit reached (8928), increase request interval or time range, requested datapoints = 51840"}
is it possible to change this limit of 8928 records? rather than having to pull the data every min ie a smaller sample rate?
I am aware this may have a performance impact on a live unit.
is this just a hardcoded limit i can just change or are there other ramifications i see a reference to it in
emoncms/Modules/feed/engine/PHPFina.php
emoncms/Modules/feed/engine/PHPTimeSeries.php
ChrisValentine's picture
Re: CSV export problems - Request datapoint limit reached (8928)
Have you tried increasing the amount of memory PHP can use via php.ini ?
This is just a hard coded limit, your welcome to increase it, it will just result in a request that takes longer.
dafyddhirst's picture
Fantastic Thanks for the conformation i have increased both memory and limits and can say so far its still stable. Slow on big exports but thats to be expected.
