Mysql fails on emonSD-17Jun2015.img
on a fresh and clean install using dd method the image emonSD-17Jun2015.img put on a 4GB SD card on a Raspberry Pi B+ fails to start initially and bring up the configuration/registration interface.
Searching for previous solutions did not work, the closest I found suggested mysql password reset, however mysql would not even start in safe mode. Assuming that not many people have this problem on clean setup, this could be a specific failure with my setup, but ideas are welcome.
pi@emonpi ~ $ sudo mysqld_safe --skip-grant-tables &
[1] 7923
pi@emonpi ~ $
pi@emonpi ~ $ 151209 21:32:49 mysqld_safe Logging to syslog.
pi@emonpi ~ $
pi@emonpi ~ $ 151209 21:32:49 mysqld_safe Starting mysqld daemon with databases from /home/pi/data/mysql
151209 21:32:50 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
