Need help reading the logs:
Below is my emonhub.log view file.
can someone tell me what the (unreliable content) means?
7) 2015-10-22 11:58:41,101 DEBUG RFM2Pi 401 NEW FRAME : OK 10 41 0 33 0 10 0 7 0 205 1 0 0 0 0 0 0 0 0 0 0 0 0 8 9 (-30) 2015-10-22 11:58:41,103 DEBUG RFM2Pi 401 Timestamp : 1445479121.1 2015-10-22 11:58:41,104 DEBUG RFM2Pi 401 From Node : 10 2015-10-22 11:58:41,104 DEBUG RFM2Pi 401 Values : [41, 33, 10, 7, 4.61, 0, 0, 0, 0, 0, 0, 2312] 2015-10-22 11:58:41,105 DEBUG RFM2Pi 401 RSSI : -30 2015-10-22 11:58:41,106 INFO RFM2Pi Publishing: emonhub/rx/10/values 41,33,10,7,4.61,0,0,0,0,0,0,2312 2015-10-22 11:58:41,107 DEBUG RFM2Pi 401 adding frame to buffer => [1445479121, 10, 41, 33, 10, 7, 4.61, 0, 0, 0, 0, 0, 0, 2312, -30] 2015-10-22 11:58:41,108 DEBUG RFM2Pi 401 adding frame to buffer => [1445479121, 10, 41, 33, 10, 7, 4.61, 0, 0, 0, 0, 0, 0, 2312, -30] 2015-10-22 11:58:41,109 DEBUG RFM2Pi 401 Sent to channel' : ToEmonCMS 2015-10-22 11:58:41,715 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 179 29 197 129 21 58 105 194 211 197 40 190 241 163 8 20 61 237 166 206 188 (-99)
Mark
Re: Need help reading the logs:
Hello @stanleyind, the unreliable content you see there is radio noise that its picking up. It is quite normal to see a lot of this if quiet mode is set to false in emonhub.conf. You can switch these off by setting quiet mode to true.
stanleyind's picture
Thanks Trystan, will see if that works.
Mark
The clue is "(-99)" - that is the received signal strength and it's far below the "OK" message earlier which shows (-30).
