Problem compiling EmonGLCD scripts (e.g. SolarPV.ino) with Arduino 1.60
When I try to compile, I get the following error messages.  Is this a known problem and is there a workaround?
In file included from E:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from E:\Users\jlm_2\Documents\Arduino\libraries\jeelib/Ports.h:10,
                 from E:\Users\jlm_2\Documents\Arduino\libraries\jeelib/JeeLib.h:17,
                 from SolarPV.ino:44:
icons.ino:2:42: error: variable 'icon_heating_8x16' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
icons.ino:16:35: error: variable 'icon_home_13x12' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
icons.ino:21:36: error: variable 'icon_lines_12x12' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
icons.ino:26:42: error: variable 'icon_solar_12x12' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
Error compiling.
I note that this problem came up in 2013 here; the solution was to change Arduino versions: http://openenergymonitor.org/emon/node/2564
Re: Problem compiling EmonGLCD scripts (e.g. SolarPV.ino) with Arduino 1.60
As far as I am aware, the icon data is not changed at all, therefore have you tried declaring the offending variables as "const" (in icons.ino)?
I am running Arduino 1.0.5 under Linux so I do not see the error when I compile that sketch.
[Edit:]
A Google search for "Arduino 1.6 compile error const read only" shows that you are not the first to see that error. It would appear that the newer version of the Arduino IDE enforces stricter rules for declarations. One of the suggestions was as above - add "const" to the declaration.
Yes, that change went into gcc 4.6 (https://gcc.gnu.org/gcc-4.6/changes.html)
Arduino 1.0.5 ships with avr-gcc (GCC) 4.3.2, and Arduino 1.0.6 ships with avr-gcc (GCC) 4.8.1
If you find the solution to this please make the changes to the github code to send us a pull request so we can get this fixes for everyone. Thanks
jmessenger's picture
I have added const to the declarations and this works.  I have submitted a pull request on github for this.
