Input difference (mis)calculation
I have 2 inputs on my installation that need to do difference calculation:
IN1 - holds energy (KWh) of floor 1 and 2;
IN2 - holds energy (KWh) of floor 2;
So in order to calculate the KWh/d of only floor 1, i configured IN1 like this:
-input IN1
kWh to kWh/d, Energy floor 1
But the feed "Energy floor 1" is always 0.00
What can I be doing wrong?
My emoncms is v8.3.6.
JD's picture
Re: Input difference (mis)calculation
I think you should be using "power to kWd" not "kWh to kWd"... the inputs report power in watts (W), not energy (kWh).
xgon's picture
The value on the inputs are indeed kWh. The point is not the units, but the input calculation (in this case the difference)
