emonGLCD not programmable
Submitted by adebree on Sat, 11/08/2012 - 11:11Hi there,
Just about to finish the first component from the Home Energy Monitor kit, the emonGLCD. The problem is that I am unable to upload any sketch to it using the USB to UART loader from the OpenEnergyMonitor shop. The SILabs driver is installed. To isolate the problem as much as possible I did the following:
- used the minimal sketch possible, with just to empty void loop and setup functions.
- IDE is functional (1.0.1), uploading it to a duemilanove board I had lying around works correctly
- problem is reproducable on both my Mac OSX Mountain Lion and Windows 7. Both report the USB programmer driver is loaded succesfully.
- the soldering and components are triple checked. I did get that 3.3v measuring on the JeePort. The C13/C14 rotation is done as per instruction.
When I try to upload the sketch using the IDE and put it to verbose I get the following output:
Binary sketch size: 466 bytes (of a 32,256 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/tty.SLAB_USBtoUART -b115200 -D -Uflash:w:/var/folders/5w/nv57j_052v3_mcjbsf3x062w0000gn/T/build4219918415764378418.tmp/sketch_aug11a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/arne/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.SLAB_USBtoUART
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_recv(): programmer is not responding
avrdude done. Thank you.
Is there anyway to investigate this problem any further?
Re: emonGLCD not programmable
Just finished the emonTX and having the exact same results with that component. This makes the USB to UART component (or it's driver) the prime suspect. Is there anyway to verify it's correct (or incorrect) functioning?
Since the Duemilanove uses the same ATMEGA328 as the emonGLCD I figured, why not use the Arduino to program the chip and than put in into the emonGLCD. So uploaded the test sketch to a chip using the Arduino and installed that on the emonGLCD which worked.
I guess it is indeed an issue with the USB to UART loader. Dmesg on my mac says when inserting it:
Where especially that last line wories me. Does that mean the loader itself is having a problem?
