CT (flux) saturation
just learned about saturation the hard way:
i play with current measurement, CT N ( turns) and burden resistor and i run into that problem.
Background: for a given current transformer if the burden resistor is to high and the primary current to high
the CT goes into saturation. ( can find lots of references here too, but interesting to read www.idc-online.com/technical_references/pdfs/electrical_engineering/current_transformer_concepts.pdf )
Symtoms for CT in saturation:
 - for calibrating EMON by a low current get a ICAL factor.
   but when you test it with a high current need a ICAL factor twice or more
 - when calibrating PhaseCAL to get p=1.0  with a OHM LOAD need high values ( 4..) instead the default 1.7
and that is how my arduino inputs looked like ( Ain range 0 .. 1023 for 0 .. 5V with 2V5 AC offset)
volt current
here i exceeded the prim. AC current (1.7A)
for the CT ( N = 1000 )  and used burden resistor (470ohm) measuring range is only about 1A.
Re: CT (flux) saturation
kllsamui's picture
thanks, very good link.
only using arduino and no scope available it was very interesting for me to see that current plot.
as the CT is less 1$ i still think its worth the extra work.
a combination of range adjustment by burdenresistors
 - one big soldered to CT  ( low ampere range )
 - one small parallel to it by jumper ( high ampere range )
+ using the trick to loop the primary current 2..3 times through the CT  for increase sensitivity for low currents
gives many possible configurations.
but just lookout for that saturation trap.
