Submitted by TrystanLea on Mon, 25/06/2012 - 13:09.
Hello Lloyd is there any chance you could have copied in the textarea html, when copying from word or something? Its very strange that it should appear, I cant get to the bottom of it.
I don't believe I copied anything, just made an edit on my android phone. I also seem to have screwed up a PM in the same way. I'm writing this with the plain text editor, just in case.
Re: Problem with topic
Trystan
I don't believe I copied anything, just made an edit on my android phone. I also seem to have screwed up a PM in the same way. I'm writing this with the plain text editor, just in case.Lloyd
That seems to have worked, Im going to do a full upgrade on the site just incase, I will see if I can edit with my android phone too,
Ok, it seems to work fine from my android. how strange..
I have just updated fckeditor and drupal core, could you try saving text from fckeditor again?
This it's using plain text editor. There was html present that I removed.
The two posts above were using the rich text editor.
