need language support : emon library public variables - RESOLVED
need language support : emon library  variables
there are public and private variables  in EmonLib.h,
can i use a public variable like Vrms in main loop?  ( use example voltage_and_current )
Serial.print(Vrms); does not compile!
kllsamui's picture
Re: need language support : emon library public variables - RESOLVED
SOLVED:
  Serial.println(emon1.Vrms); // works
That is because Vrms is a property of the class "EnergyMonitor", which you have instantiated as "emon1".
If you had several instances of the class EnergyMonitor, as you do in the sketch EmonTx_CT123_Voltage.ino:
EnergyMonitor ct1,ct2,ct3;
Then you would use
Serial.println(ct1.Vrms);
Serial.println(ct2.Vrms);
Serial.println(ct3.Vrms);
