Good job on getting the house graphs in the editor.
Any joy on getting display of values available? When I try and add by hand (div class="value"><span class="kwhd"> </span> kWh</div>) the editor strips the span tags out.
I've have now found that sometimes the span elements stay, sometimes they get deleted. In the attached file, the last two get deleted (Voltage and ImmVRms).
Re: Add buttons to Dashboard Editor
And a second question - how do I add the display of a feed value graphically, as the editor seems to have stripped all mine out?
Lloyd
Anyone ?
Lloyd
First question... i am on the way :-) (can you paste html code? )
Second... can you paste the html code here too so could make a class style to better display?
Best regards
ilde
This is the code I use for the led and import/export meter:
<div class="led" feed="feedname"></div>
<div class="widget">
<div class="title">Import/Export</div>
<div class="centredial" feed="ImportExport" max="10000" units="W" scale="1"></div>
And this should display a value, where kwhd is the feed name:
<div class="stats" style="height:70px">
<b>Energy used today:</b><br>
<div class="value"><span class="kwhd"> </span> kWh</div>
hope this helps,
Lloyd
There is also this widget which is good on a dashboard:
<div id="house-graph" class="graph" feed="power"></div>
See here: http://openenergymonitor.org/emon/applications/homeenergy
Lloyd
Hi Ilde
Lloyd
Thx!!!
i insert your code and it doesnt happend to me.... :-o
The code works fine for me :-(
did you test it in lastest version? could you send me the complete html code (maybe some other code breaks the parser )
Best regards
ilde
Lloyd
