Port Emonlib to Mega 2560
I´m planning in using th eEmonlib on the ATmega 2560.
With which modifications should i be careful?
Is the Clock frequency (16MHz) a problem ?
Best regards
Re: Port Emonlib to Mega 2560
The clock on the Atmega328 also runs at 16Mhz, I don't have any experience using the 2560. Please let us know how you get on.
Robstar's picture
Atmega328  EmonLib.cpp
long EnergyMonitor::readVcc() {
  long result;
  ADMUX = _BV(REFS0) |  _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2);
  ADCSRA |= _BV(ADSC);
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = 1126400L / result;
  return result;
change ->
Atmega2560 EmonLib.cpp
  long result;
  ADMUX = _BV(REFS0) |  _BV(MUX5) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2);
  result = ADCL;
  result |= ADCH<<8;
  return result;
