emoncms dashboard
Submitted by Guest on Mon, 07/05/2012 - 11:47A few questions:
Since the new dashboard editor arrived, things have become a little confusing. I can't seem to close the editor - it is always present. I only want it present if I want to edit the dashboard, how can I do this?
Secondly, I can't seem to get the main graph to work, it is loading the forward and back arrows but is not populating with any data, I have ensure thge READ API key is correct and tried changing to different feeds but nothing seems to happen.
Dave
Re: emoncms dashboard
I found the same, but if you only want to display your dials etc. then go to this url:
http://vis.openenergymonitor.org/emoncms3/Vis/Dashboard/embed.php?apikey=YOURREADAPIKEYHERE
No changes can be made (that I know of) so is better for general viewing anyway.
EDIT - I've made an assumption your accessing the demo emoncms3 online, so the above may not be applicable otherwise.
Dennis
