Time setting on emonglcd
Hi all,
I get my time from the emonbase connected to the internet, but the time displayed is GMT and not GMT+2 where I am, time on computer is correct, also get the computer time from the internet, do you have to set it somewhere?
Thanks!
esawyja's picture
Re: Time setting on emonglcd
Anyone please?
logic's picture
I've had to do this for displaying BST so I added to the line (hour+1) but unfortunately I can't access my program just now to tell you exactly where I added this
I'm just replying to let you know that I will find out and post back hopefully within a day or two, incase you don't get any further responses.
Drsdre's picture
I've fixed the time issues temporarily by adding the following line in the Nanode RF sketch:
// UTC+1 for CET, +1 for summertime
now = now.get() + 3600 + 3600;
To be added right after DateTime now = RTC.now(); (after line 266 in Solar sketch).This solution requires a upload of a changed sketch at the beginning and end of summertime (with or without an additional 3600 seconds). I've did some investigation in using a timezone library (https://github.com/geneReeves/Arduino-TimeZone-Time) unfortunately this requires a re-implementation of the current time library.
Another option would be to determine the local timezone in emoncms3, which requires generating a date/time output which NanodeRF will parse instead of using the HTTP header time.
esawyja's picture
Thanks for the suggestions, let me try that
esawyja's picture
Nice, just did the change on the NanodeRF and that works a treat, we do not do the summer time change in South Africa, so I do not need to worry about that, thanks for the help!!
  // GMT+2?
  if ((!now.hour()==0) && (!now.minute()==0)) {
    emonbase.hour = now.hour();    //don't send all zeros, happens when server failes to returns reponce to avoide GLCD getting mistakenly set to midnight
      emonbase.mins = now.minute();}
