Adding a Nokia 3310 LCD screen
OLD ARCHIVE - some info might be out of date
The Nokia 3310 LCD screen is a plug-n-play display shield. Thanks to Nuelectronics. It's a really neat way of displaying lots of information without a computer. This page goes through connecting it to Mains AC. Non-invasive 3.0, but hopefully gives enough information to interface it with any of the other basic setups or any other project.
The LCD can be ordered form nuelectronics for £9.99 here.
Step one: Making a breakout adapter
To use the display at the same time as the sensor electronics, an adapter is needed to make 5V, GND, Analog input 1 and 2 accessible. Here are couple of pictures of the way I did it. You will need two 6x3 pieces of stripboard and two 6-way sockets
Once you have that done, plug the shield into the Arduino and connect the GND, 5V and analog inputs wires 1 and 2 from the sensor electronics to the breakout pins. That completes the hardware part, on to the software.
Step Two: Software - installing the library
To run the LCD, the nuelectronics LCD library is needed. Download it here, then unzip it and insert it into your Arduino/libraries folder.
Step Three: Software - Arduino Sketch
Download the LCD Mains AC: non-invasive 3.0 sketch here: MainsACemonAndLCD.tar.gz. Unzip and upload to your Arduino.
Thats it! When you turn it on, the screen should light up nice and blue and be displaying useful information!
More information on the added bits of code
There are three blocks of code that need to be added:
The first block goes right at the top of the program, it includes the LCD library, sets up the LCD and declares the variable used to convert integers to characters.
