emoncms
Submitted by PeterN on Tue, 01/05/2012 - 12:11Great work guys. I found it very easy using your guide to install emoncms and get working. Hope you can spare the time to answer two questions for me: Firstly where is color code for Realtime and Bargraph data ( I found Dashboard dials at location - ....Vis/Dashboard/widgets/dial.js. Second question can labels be added for x - axis e.g. kWh.
Cheers
Peter
Re: emoncms
Hello Peter
The color codes are currently pre-set within the flot graphing library, however it is possible to change the colors and add titles labels etc using the flot api. http://code.google.com/p/flot
Their api is well documented, take a look at the examples in particular here: http://people.iola.dk/olau/flot/examples/ and click on view source to see how the options are set etc
Then set the options here:
https://github.com/openenergymonitor/emoncms3/blob/master/Vis/flot/scripts/inst.js
line 61 onwards for the raw data graph.
All the best
Trystan
