Some people were seeing the ATMega328 brown out and reset when initialising the ENC28J60. This is fixed by adding an extra 10uF electrolytic cpacitor between Vcc and GND. The best place for this is the space for the ISP connector. Long leg goes to pin 2, short leg to pin 6
If you look at the board schematic here http://solderpad.com/monsonite/nanode-rf/ The only pin 1 and 6 are marked so im guessing this. (you can zoom the pic., Numbers in Gray )
Re: avrdude: stk500_getsync(): not in sync: NanodeRF - RESOLVED
Removed the cap
Step 25b - Capacitor Fix
and now it uploads
WT&?
It looks to me that you have the cap in the wrong place.. think you have pin 2 and 3 baised on "IMAG0169.jpg" not 2 and 6 See pic below.
You need to connect the pos to pin 2 (nearist D4) and neg to pin 6 (nearst D2)
Rob
Hi Rob,
How does it count, the same as a IC, Pin1 on the left, counting down and then to the right top?
1 4
2 5
3 6
or in your explanation
1 2
3 4
5 6
Thanks for the feedback
2 4 6 FDDI : : : 1 3 5 USBIf that makes sence..
Thank you sir
No problems.. Hope this works for you...
