Multigraph by default on day, how to arrange this
Hallo there
i have question about the multigraph, i like be default to have this graph on a day instead of week. it looks like it not configurable. is that true? if not how can i arrange this.
every time i start the site i must first click on day.
Thanks for your help on forward.
Chris
Re: Multigraph by default on day, how to arrange this
Hi Chris
The default view is set when you save your multigraph in 'Visualisations'.
​So if you want to set a day view instead of a week, open the multigraph up in Visualisations (Vis) select the default view of your choice, and save it.
When you then import the multigraph into a Dashboard, it will open in the 'day' view.
calberts's picture
Thanks Paul
I checked it, i went to Vis selected first my multigraph and in the graph i clicked on day
than hit the save button, but it looks like its not saved. when creating the graph new in the dashboard
it's still week.
i created total new one the same issue.
Any idea why its not saved?
PS. (Update) But when i add fill and click on save it save and is  seen in the dashboard
Chris
This was discussed here, and the fix merged some months ago. You haven't said if you are using emoncms.org or self hosted (and which version).
