Emoncms Raspberry Pi image without emonhub?
I wish to use the pr-prepared image for the raspberry Pi but not use emonhub.
I already use a current cost Envir monitor with a serial to usb link and a small perl program which feeds the data to emoncms.org.
But i would like to set the raspi up as a local webserver so i can access the dashboard locally and through the internet.
So i guess i need to turn off emonhub as it is not doing anything.
Is this possible?
Re: Emoncms Raspberry Pi image without emonhub?
if you run
sudo update-rc.d -f emonhub remove
that should remove the auto start script so emonhub can only start if you manually start it, so you can just leave it dormant in case you change your mind later.
