KWh to Power -> suspicious values
I have a energy meter that gives 1600pulses/KWh. So 1pulse=0.625Wh. I want to send to emoncms energy (Wh) and calculate instant power.
I send always the pulse difference.
I'm setting up a feed like this:
1    Log to feed    node:0:energy_log
2    x    0.625
3    Wh Accumulator    node:0:energy
4    x    0.001
5    kWh to Power    node:0:power
The Wh accumulator is ok.
At the moment I'm sending test values (random values between 1 and 10) every 5 seconds.
So the power should be between 450W (1*0.625/5*3600) and 4500W (10*0.625/5*3600), but the power sometimes is zero...
What I'm doing wrong?
Re: KWh to Power -> suspicious values
The Wh accumulator will subtract the current value from the last value as it increases and totals the difference. I think you want a standard "accumulator" that will just add each new value to the total, the first "log to feed isn't essential either, so you could try
    x    0.625
    x    0.001
xgon's picture
Thanks for the reply,
It works as expected.
Thanks.
