Own goal... can I recover from a silly mistake?
Good news is that me self hosted EmonCMS 8.3.6 server is running and all is good.
I was trying to setup a working FTP client so I can upload some custom javascript charting content based on d3 (pretty cool stuff by the way).
Anyway- following this tutorial (http://www.instructables.com/id/Raspberry-Pi-Web-Server/step9/Install-an...) I screwed up.  I changed the pi user in file /etc/passwd as described, after setting the root password as described.
I realized I'd messed up by not logging on as root (which of course cannot log on with user root) before changing the /etc/passwd file.
sudo no longer works with user pi... and I can't log on with user root.  Now that I've timed out and disconnect my session I can no longer login with pi.  So basically - I've lost my admin rights on my pi.
Does anyone have any thoughts on another user I can regain admin access to my pi on a standard EmonCMS build?
If I boot my pi and connect with a keyboard and monitor can I use the root user?
In a bit of a pickle....
Re: Own goal... can I recover from a silly mistake?
If you can get logged on to the root account - with a local keyboard/monitor - then yes, you'll be able to edit the passwd file to remove the # character. If you can't log on locally, then an alternate solution would be to mount the card as a second volume on your Pi while booted from another SD card. Mounting the card on another Linux box would be yet another choice.
Regards,
Bill
Keen2bGreen's picture
Bill - you're a star!  Thanks for that encouragement to fish out a USB keyboard and hook up a monitor.  All sorted now.
Let's see what I can mess up next!
Cheers
Mike
You're very welcome, sir! Good to hear you got it going again.
