Tooltips on values of multigraph
Submitted by mharizanov on Fri, 20/04/2012 - 18:47I just added some code to show tooltips with the values when you hover over a multigraph value, here is a screenshot:
To do this edit multigraph.php and add the checkbox code whereveer you want it
<p><input id="enableTooltip" type="checkbox" checked >Enable tooltips</p>
and the javascript at the end of javascript code, just before the </javascript> closing tag:
function showTooltip(x, y, contents) {
$('<div id="tooltip">' + contents + '</div>').css( {
position: 'absolute',
display: 'none',
top: y + 5,
left: x + 5,
border: '1px solid #fdd',
padding: '2px',
'background-color': '#fee',
opacity: 0.80
}).appendTo("body").fadeIn(200);
var previousPoint = null;
$("#placeholder").bind("plothover", function (event, pos, item) {
$("#x").text(pos.x.toFixed(2));
$("#y").text(pos.y.toFixed(2));
if ($("#enableTooltip:checked").length > 0) {
if (item) {
if (previousPoint != item.dataIndex) {
previousPoint = item.dataIndex;
$("#tooltip").remove();
var x = item.datapoint[0].toFixed(2),
y = item.datapoint[1].toFixed(2);
// create a new javascript Date object based on the timestamp
var date = new Date(parseInt(x));
// hours part from the timestamp
var hours = date.getHours();
// minutes part from the timestamp
var minutes = date.getMinutes();
// seconds part from the timestamp
var seconds = date.getSeconds();
// will display time in 10:30:23 format
var formattedTime = hours + ':' + minutes + ':' + seconds;
showTooltip(item.pageX, item.pageY,
item.series.label + " at " + formattedTime + " = " + y);
else {
Re: Tooltips on values of multigraph
Thanks for that - it was just what I was looking for.
Lloyd
And interesting that the tooltip gives the correct time, whilst the axis is an hour behind.
I've also made as slight change to the code to format the time better:
ive got the same issue, my x axis are 2 hours off whilst the tooltip shows the correct hour. any idea why this could be?
I am using unix timestamp saved in a database of my own.
Thank you very much
Great addon, thanks
Mine is also off, quite irritating.
I did a temporary sort of fix,
I changed this part, added the text in yellow
just inserted the code, but no tooltips at all.
Is this working with emoncms v3?
Kisskovi
v3 changed a bit, use this line
$("#graph").bind("plothover", function (event, pos, item) {
instead of
and it will work (tested)
Does this also work with the new modular version?
Haven't tested, but this is FLOT functionality, so should work, and if not - minimal effort would be required to get it going
it solved my problem,
thanks!
