Migrating emoncms to bootstrap 3?
Hei,
I was wondering if anyone has tried migrating the Emoncms to use the twitter bootstrap v3. Or if the reason why the project is still using the v2 is because it would be too laborious to migrate.
I was thinking of trying http://code.divshot.com/bootstrap3_upgrader/ or to search for the main class changes described in http://getbootstrap.com/migration/
If anyone has some experience with it, please share.
Cheers,
tcarlyle's picture
Re: Migrating emoncms to bootstrap 3?
In case someone gets interested in the task, I've checked and there is a bit more than 70 terms spread in around 15 files that would need to be ported. I've got those numbers by running a python script http://pythonhosted.org//b2tob3/ (with a small modification to include php files) that does the conversion (though one is supposed to use versioning control and review the changes) and outputs the nb of changes.
As expected, the simple running of the python script resulted in some weird layout and broken links. I dont feel like I know the code or bootstrap enough to do the migration, but I hope the notes here can be of any help.
Cheers
