Flush mount temperature sensor
Hi there,
I'm attempting to monitor the temperature in several rooms of my house.  Has anyone come up with a good way to conceal the DS18B20 device when using it for room measurement?
Are there any flush mount sensors that work with the EmonTXv3? - something like this?
https://homeauto.com/Downloads/Products/Accessories/23A00-2.PDF
M
Andrew Wedmore's picture
Re: Flush mount temperature sensor
Buy an electrical box, such as you would use for a light switch (either a metal box let into the wall, or a surface mounted patress, whichever suits your house).
Fit it with a blanking plate (eg http://www.diy.com/departments/crabtree-1-gang-single-white-urea-blankin... )
Glue the sensor to the back of the blanking plate using thermal glue.
madas's picture
do you think that will read the temperature of the room more than the temperature of the void behind the drywall?
I was wondering about putting it inside the return vent for the heating system.
Any thoughts?
madas's picture
Ah - I guess i'll get a couple of these the next time I order!
http://shop.openenergymonitor.com/emonth-case-white/
