Increase log interval to more than 1hour
In a multigraph vis for temperature I would like to get:
- current temperature (easy)
- daily averaged temperature and even may-be monthly averaged temperature
I thought about an easy solution to get averaged value: use the PHPFIWA engine. Unfortunately, the max interval is 1 hour. Would be nice to increase it in order to create average value that can be displayed in multigraph...
lassetobiasen's picture
Re: Increase log interval to more than 1hour
Hi Darrepac,
I was searching the forum and found your post: Did you find a solution to the above?
I am also looking for a way to produce averages beyond the 1hour maximum internal, which is currently set in the PHPFIWA engine.
Have been considering download the code and making the adjustment myself, but that seems like a bit of work...
Kind regards
Lasse / Denmark
