using jeelink as a substitute for emonBase
Submitted by Guest on Mon, 16/04/2012 - 12:26
Hi All,
I am considering alternatives to the standard emonBase. I already have a small linux box (PC Engines ALIX 3D2) running a weather data logger (http://www.wfrog.org) which can accomodate some extra computations (emoncms in this case). I'd like to see the feasability of using a jeelink plugged in one of the two USB ports of my linux box. I don't like the idea of having to power another box just to send data to the emoncms host when the data can be received directly.
I understand that this is not difficult and that jeelink can be easily configured to receive the data (http://openenergymonitor.org/emon/node/488)
Is emoncms prepared to receive data from jeelink's serial port?
Any advice in this setup?
Thanks and congratulations for this great work!!
Jordi.
Re: using jeelink as a substitute for emonBase
Where do you plan to store Emoncms?
Sometimes I use JeeLink to receive the sensors data and JeeMon is posting the data to Emoncms. I think you can use JeeMon on your linux box too...
