How to clear all datapoints?
Hi guys...
i have asked this a lot and there it seems that nobody knows....
but are thare not a command i can fire so that the datapoints are cleared but everything else i keept intact...
i want to do this when the pi finds its final install place... for now its on a shelf near the router and not in the utility closet where i want...
so the data its logging now is just kind of test data... but i have build dashboards etc just to my liking... dont want to do that all over again
Re: How to clear all datapoints?
Bo, can you edit your post and give it a proper title please, relative to the issue that you are raising.
Calling it '@Glyn or Trystan' is not helpful when members review or search posts, and directing your question to named persons goes against forum etiquette.
If you wish to restrict your question to T&G, then perhaps you should PM them instead of posting in a members forum.
Paul - forum moderator
Edit 2/10 --> Post Title changed by me....
boelle's picture
well... i have asked and no other user knew... i could PM them but then the other users would not benefit from the answer....
the @ was just to attract attention...
EDIT: have put back the @ part but also keept the better topic...
EnergyRnR's picture
I would use phpmyadmin and delete the data you don't need ( i.e. between certain dates) in sql.
Another option, if you have too much data, would be to just save the source for the dashboard (i.e. back them up) and then d a clean install of everything from the beginning. Then manually put the dashboard source code into sql, and do some minor edits in emoncms to set up the appropriate feeds.
Eamonn
If you delete, then recreate your feeds, that will do what you want. After recreating your feeds, you'll have to go into the dashboard editor and reassign the feeds to your widgets and visualizations, but you shouldn't have to rebuild them. I've done this several times with no problems.
@boelle, Seconding Bill Thomson, deleting and recreating the feeds is currently the way to do this. A clear feed function would be a nice feature to add.
boelle's picture
I think i will opt for the phpmyadmin way....
deleting all feeds and recreate them means that they are not in sync so to speak.... my feeds for district hot water has to start at the same time so i can compare them...
but yes a clear all data botton would be damm nice :-D
boelle's picture
how would you do it via phpadmin? i can see the feeds table but not the data...
boelle's picture
could it be that its now timeseries and not sql? so i have to edit a text file instead and clear it that way?
boelle's picture
figuered one way to do it
log in as pi
go to /data/phptimeseries... simply delete the feed file you want to clear...
wait a bit and the file is recreated
can an expert confirm its a valid way to do it?
boelle's picture
did almost work... it keeps the last data... prob because the logging is running in background
I assume you are using the latest SD card image. you could try stopping emonHub before deleting the feed data
    sudo service emonhub stop
and then after you've finished
    sudo service emonhub start
But if you still have "old" data showing up after that, you may need to try again but this time also flush any data from redis
    sudo redis-cli FLUSHALL
will flush all redis data from all feeds.
The "safe" way is to delete the feed as previously suggested but in theory yes there should be a way of deleting just the feed data. You can see what happens when you delete a feed the correct way in emoncms by looking at this code.
https://github.com/emoncms/emoncms/blob/bufferedwrite/Modules/feed/feed_model.php#L436
It seems 3 things are done:
  1. Delete the feed, which you are doing
  2. Delete the SQL data - which you don't want to do so that it's retained
  3. Delete redis data.
Then if the data feed is recreated ok it would appear this method works. There is also a feed value retained in the SQL table but I do not know if that will effect the new data or not so you may also need to delete that value also but its unlikely.
Interested to hear how you get on.
EDIT - in fact you will probally also need to stop apache, depending on the data feed type, as even with no new data coming in to emonCMS the data engine may continue to create data points at regular intervals.
boelle's picture
having gotten my kwh data poisened by the 1970 issue i would wish emoncms came with a tool to edit datapoints rather than clearing data
