Meter Readings
Currently i use a Raspberry Pi and a Logging-script to collect and calculate my Enery consumption and Cost.
Daily i calculate the low and high tarrif cost based on Meter Readings.
For example : every 10 seconds i register the meter readings. I use the first and the last meter reading to calculate. : first reading : 1663.568 KWh second reading (end of day) : 2000.453
My question (i searched this forum for an awnser but most is based on current usage) : Is i possible to register these meter readings in EmonCMS. What is the best way ?
Does anyone have a direction for me where to look or what filter to use.
  Bernard
bernard's picture
Re: Meter Readings
I came around this post : http://openenergymonitor.org/emon/node/3329
"To validate the data you can write down your actual reading on the energy meter at 00:00 and do the same 24h later. Subtract the two values to get the actual daily energy usage. Now its easy to compare it to your data in the emoncms."
Or do I have to apply a particiular filter ?
This means I can register total Energy Usage in EmonCMS.
however : how do I do this ? Is this just logging to a feed and setting it to Daily ? or  do I need a particular filter or setting for this ?
Thanks in Advance
[Two very similar posts merged - RW (moderator)]
bernard's picture
Re: Meter Readings
"[Two very similar posts merged - RW (moderator)]" is added to my last post ...but .. no answer to be found.
Does anyone has experience with this ?
