Solar PV Monitoring System
Submitted by PeterN on Tue, 10/04/2012 - 12:18Hi,
Got my PV kit last week. EmonTX assembled and seems to be working (with emonTx CT_123_voltage sketch) ok. The NanodeRF (868Mhz) is assembled,Voltages tested ok. Side note the build guides were excellent ( from a complete novice )
I can upload NanodeRF_Power_RTCrelay_GLCDtemp and sketch loads ok. However now I cant get them to communicate or more to the point the nanoderf to receive anything, from emonTX, emonTX is set node ID 10 group 210 and NanodeRf is set node ID 15 , group 210 and both 868Mhz.
Now whne I look at com port for the nanoderf I see nothing (yesterday I was getting the following:
DHCP status: 0
2 {rf_fail:1}
Being a novice I have played with this for a few days and learned a lot but it is still not working. Thinking I should start by testing the RF12 I have tried the simple test with Ian's RFM12B Test code but keep getting error compling (Ports.h:10:22:error: WProgram.h no file or directory ).
My nanodrf Board is set to Uno and using latest Port and RFM12B versions
I did notice that atenna is 100 mm and not recommended 82 mm for 868Mhz
Please advise on next step.
Cheers
Peter
Re: Solar PV Monitoring System
Looking better but did nothing new, I'm getting see extract below - to me this implies my assembly e.g. soldering or something, my question above relating to antenna length still stands - its is now 100mm so question is do I cut it down to 82mm as recommended for 868Mhz.
DHCP status: 0
1 emontx packet rx2 {rf_fail:0,power1:21,power2:41,power3:0,voltage:3274}
DHCP status: 0
2 {rf_fail:1}
DHCP status: 0
1 emontx packet rx2 {rf_fail:0,power1:26,power2:41,power3:0,voltage:3274}
DHCP status: 0
2 {rf_fail:1}
Try using our RFM12B tester, if you have the emonTx working just use the Rx sketch to receive the data: https://github.com/openenergymonitor/RFM12B_Simple
Looks like DHCP Is more of the problem? The router is failing to give the nanoderf an ip address. It might be worth trying a static ip.
This discussion has moved to http://openenergymonitor.org/emon/node/550
