because the column Last update
hello everyone,
I wanted you asked why I left it off for 3 days emontx, now in the last column uddate remains "inactive" when I see, however, that the data on the dashboard reading change.
What happened ?.
Thanks in advance for the help
Re: because the column Last update
What set up do you have ?
The "inactive" time is counted from the timestamp of the last received data, so it you make a new submission of old data it would update but still be classed as inactive despite the values changing.
serbat's picture
Use 1 1 emontx and raspberry.
kindly advise me what to do?
in this way, however, does not record anything on the database, right?
What software are you running on the Pi?
Where is emonCMS hosted local, on the same Pi or remote ?
Looking at your screenshot the data is fairly recent (1hr 15mins) and will be updating the database. but it maybe updating with newer data if you have new data being forwarded.
Is interval getting shorter? Are you forwarding new data?
serbat's picture
Grazie pb66
I'm using the local version, use software such as "emonSD-13.08.14" updated, the last update was 2 hours ago, and then in sequence becomes inactive
Restarting emonHub will clear the buffers
sudo service emonhub restart
and to clear anything in redis you could try
sudo redis-cli
> flushall
serbat's picture
ok, I try
serbat's picture
I tried the advice, but nothing has changed, I've done something wrong?
It looks like it has changed because now you have all zeros and "inactive"
If you are try typing
tail -f /var/log/emonhub/emonhub.log
you should be able to see the data packets in emonhub.
serbat's picture
I answered so
the distance between emontx and raspberry is 5Mt, divide by a wall from 30cm
The date in the log shows 1970-01-01 this means there is another problem. if you type " date " I think you will find there is a problem with the Pi's time and date. someone else had this issue but they started a fresh install so we didn't find the cause.
We could try and find the problem but If you don't have much data it may be much quicker and easier to just a fresh image.
serbat's picture
now I'm at work, I'll try to return soon enter the "date", then see what happens.
In fact it is not the first time that happens to me and other times I always reinstall the image.
It may be a question that I have held off both the raspberry that emontx for 2 days, and working locally are never connected to the network / internet?
If it is useful to you and you tell me what I can do tonight to experiment
There are a couple of things we could try.
If the " date " is set to 1970 try running
cat /etc/fake-hwclock.data
I expect it to return a date string something like this " 1970-01-01 00:17:01 " if it does we can overwrite it using
sudo sh -c "echo '2014-MM-DD HH:MM:00' > /etc/fake-hwclock.data"
substituting with the current UTC time and date values. it doesn't need to be pinpoint accurate, within 10mins is fine as we can try to get it to update online using
sudo ntpd
check to see what time the Pi thinks it is now using
date
chances are it will still be wrong so try rebooting the Pi to see if the time changes, the time maybe inaccurate even if it has changed. with a network connection the time is adjusted every hour but I'm not sure if it will update AT boot then every hour or an hour after boot.
Let us know what happens :-)
serbat's picture
you will not believe .... is broken without doing anything, come home and fire up the pc and the signal was present
Fantastic, so the time will eventually correct itself if the network is available.
Thanks for letting us know
serbat's picture
no, I'm not sure of this, I will check that there are no more false contacts on solder the antenna
