[Solved] GLCD Time always start at 0:00 when powered on
G'day,
I'm using the SolarPV sketch for the GLCD. which works fine except the time always start at 0:00.
I'm in UTC+10 timezone, the emonbase shows the correct time.
I can't see any errors, what am i missing?
thanks
Andy
Re: [Solved] GLCD Time always start at 0:00 when powered on
What software are you running on emonBase ?
Is it configured to broadcast the time correctly ?
If you're using emonhub see http://openenergymonitor.org/emon/node/5679 for more info
ewiandr's picture
The 'interval = 300' was missing...
Thank you
