Trying to pass empty value with csv input api
Hi, i have an arduino monitoring power and temperature that sends the data to an emoncms server running on a RPi through a nrf24 module. To measure the temperature, i take ~50 samples and do the average, storing (and sending to the emoncms server) also the standard deviation of the measurement..
When the RPi receives the data, it runs a curl command as this:
curl "http://192.168.0.8/emoncms/input/post.json?node=10&csv=Vrms,Irms,power,Temp,TempErr&apikey=$foo
but when the TempErr (std deviation of the temp) is above 1°C i'd like to ommit the Temp value from my log (while keeping the TempErr log), so i tried adding an if statement that modifies the curl command to
curl "http://192.168.0.8/emoncms/input/post.json?node=10&csv=Vrms,Irms,power,,TempErr&apikey=$foo
my problem is that when i do that, emoncms stores a value of 0 to the temperature, which screws up my TempMin daily feed..
I have been able to do this (ommit the Temp measurement) if i use this command instead
curl "http://192.168.0.8/emoncms/input/post.json?node=10&csv=Vrms,Irms,power&apikey=$foo
but i'd like to keep track of the TempErr value to see how much off was the measurement and know if my temp sensor is way off or just a little bit off.
is it possible to do this without having to change the order of the inputs?
I'll attach the c++ code i use on the RPi side to send the data to the emoncms server (running on the same RPi)
Re: Trying to pass empty value with csv input api
Using json you can be selective about which inputs you update so something like
http://192.168.0.8/emoncms/input/post.json?json={1:Vrms,2:Irms,3:power,5:TempErr}&node=10&apikey=$foo
should work to omit the 4th value but still update the 5th
rangua's picture
hmm.. yeah, i remember i used .csv because the brackets confused bash and i didn't knew how to escape it :S
i'll research that and do it json style.
thanks
