emonGLCD no longer receiving time info from emonBase
After uploading the new emonSD-13-08-14.img to my Raspberry Pi (Model B) everything is working great with only one problem:
the emonGLCD is no longer receiving time info from emonBase :
if (node_id == 15)   //Assuming 15 is the emonBase node ID
        RTC.adjust(DateTime(2012, 1, 1, rf12_data[1], rf12_data[2], rf12_data[3]));
        last_emonbase = millis();
The Base id==15
Any idea why ?
Re: emonGLCD no longer receiving time info from emonBase
I think you need to turn it on in the RPi - try searching, I've seen a recent post about this.
You do (currently) need to add a line to emonhub.conf to activate it on the Pi. See the emonGLCD time update thread.
tsvikabp's picture
Hi Paul,
the emonhub.conf already contain the phrase  "interval = 300" :
# This interface manages the RFM2Pi module
[[RFM2Pi]]
    Type = EmonHubJeeInterfacer
    [[[init_settings]]]
        com_port = /dev/ttyAMA0
    [[[runtimesettings]]]
        group = 210
        frequency = 433
        baseid = 15
        interval = 300
any ideas ?
Thank you
Tsvika
[ 3 further similar posts deleted - Moderator (RW)]
Where are you editing emonhub.conf?
The on the emonSD-13-08-14.img it is located at /boot/emonhub.conf.
If you need to you can change the loglevel to debug and watch the new log file entries using
tail -f /var/log/emonhub/emonhub.log
you should be able to pick out the log message every 5mins confirming "RFM2Pi transmitting time: HH:MM" (you could also temporarily set a shorter interval like "interval = 10" just to test so you don't need to watch for ages)
tsvikabp's picture
Fixed !!
Thank you !
