Wrong date on simplezoom-visualisation?
using simplezoom on Release 8.3.5 I discovered the following:
Highlighting the kwhd bar of e.g. 20. Aug. he shows me 19th Aug in the upper line with the amount of kWh. The value seems to be correct, but the date is one day before.
Can anybody confirm this, or is it only a problem of my installation?
Screenshot appended.
bodiroga's picture
Re: Wrong date on simplezoom-visualisation?
Hi brutzler!
I can confirm that I'm having the same problem and I don't know what's going on. I'm also experiencing this problem:
http://openenergymonitor.org/emon/node/5453
but I am not sure if it's the same problem or not. Can you confirm if you are experimenting the same behavior?
I have a local emoncms installation, latest version from GIT in a Ubuntu Server 14.04 machine.
Thanks to anybody that is wiling to help ;)
Best regards,
Aitor
bodiroga's picture
Could someone please give us a hint? ;) ;)
I have seen that if a set my timezone as UTC + 0:00 (I live in Spain, so that's not my correct timezone, we are now at UTC + 2:00), the bars that can be seen in brutzler's post are centered around the date. That seems to fix the date problem, but obviously now the realtime representation is not correct as I'm 2 hours before my correct time.
Many thanks for your help guys and if someone needs more information about my installation don't hesitate to ask.
