Does RFM12pi work with Raspberry B+ ?
I was almost ready to order a RFM12pi when it got me thinking:
Does the RFM12pi work with the new Raspberry B+ ?
Thanks for your answers
Kind regards
greenXL
Re: Does RFM12pi work with Raspberry B+ ?
Yes it does :-)
Just for the record the Pi B+ first 26 GPOI pins are identical to the std Pi B and any add-on board that works on a std Pi B should be good on a Pi B+.
greenXL's picture
Thank you for your quick and informative answer :-)
I've read that with the B+ a lot of extension for the std Pi won't work. So I was a bit insecure.
Glad it turned out to be a misinformation
