Simplezoom and co: different behavior depending on editing from server (localhost) or from client :-(
actually working with emoncms 8.3.5 on my "W7-home-server"
I made a "simplezoom"-visualisation in a dashboard.
Its working fine, if I open the dashboard with a browser on the computer, where wamp is installed. Opening the dashboard with a browser on a different Computer via my intranet, all other widgets are displayed, but not the simplezoom-widget.
--> firefox is not able to make a connection to localhost.
Sounds like it is looking on the wrong machine. Looking with <"inspect item"> (right mousebutton and Q on the firefox), I see, that there is a codeline, that has "localhost" instead of the IP-adress of the emoncms-server.
I appended a screenshot.
EDIT:
Changing online in the console the text "localhost" to "192.168.1.2" (that's the IP-adesss of my server), the simplezoom is displayed.
EDIT 2:
Tried 2 different PCs. Always the same problem.
brutzler's picture
Re: Simplezoom and co: different behavior depending on editing from server (localhost) or from client :-(
spent 5 hours on that "problem", and have new infos:
I have seen, that the "src="http://......." is stored in the dashboard table in the mysql database.
And now the funny thing:
1.) editing the dashboard from a browser on my server (where wamp and emoncms is running)->
<div kwhd="46" power="42" id="30" class="simplezoom" style="position: absolute; margin: 0px; top: 40px; left: 40px; width: 400px; height: 580px;"><iframe style="width:400px; height:580px;" scrolling="no" marginheight="0" marginwidth="0" src="http://localhost/emoncms/vis/simplezoom?embed=1&amp;power=42&amp;kwhd=46" frameborder="0"></iframe></div>
2.) editing the dashboard from a browser on a network-client ->
<div kwhd="46" power="42" id="30" class="simplezoom" style="position: absolute; margin: 0px; top: 40px; left: 40px; width: 400px; height: 580px;"><iframe style="width:400px; height:580px;" scrolling="no" marginheight="0" marginwidth="0" src="http://192.168.1.2/emoncms/vis/simplezoom?embed=1&amp;power=42&amp;kwhd=46" frameborder="0"></iframe></div>
After figured out this, it is obviously, why the visualisation was only running on the server.
==> Is there something wrong on my server, or can anybody else confirm this issue???
And this means, you cannot import/export this dashboards on different servers??
EDIT:
My "mistake" was, that i opended emoncms on the server with "localhost/emoncms" For the future I will strictly use the IP-adress and take distance from "localhost"
Olivier's picture
If you want it to work on a local host or on a other computer you can edit your dashboard and remove http://ip and let only the /emoncms/...
This has been flagged up before, and is due to emoncms using absolute url's instead of relative url's.
