Selection " Power to Kwh/d "
Hello everyone
I'm using the version "vmaster: 8.2.8, bufferedwrite: 0.0.1", and in the other release was this voice monitoring "Power to kwh / d" now no longer see it has been deleted or replaced with another item ?
sergio
serbat's picture
Re: Selection " Power to Kwh/d "
hello guys
Nobody can help me?
boelle's picture
it has been deleted.... i have the same issue
JBecker's picture
There is a similar (same?) functionality now in the bargraph visualization of an increasing kWh feed. If you specify an intervall of 86400 seconds (=1 day) and set the delta parameter to 1 (for ENABLE or YES) then you get the desired result.
This had been discussed in a few threads already.
BR, Jörg.
boelle's picture
yep i know it has been discussed.... i tried excatly what you say but it does not work
http://energymonitor-dk.dns4e.net/emoncms/boelle/elec
JBecker's picture
I only see data from one day (also in the kWh feed). What exactly does not work?
Try to set the interval to 1 hour (3600), do you see more bars then? If delta is set to one you should get bars showing the increment for every hour.
boelle's picture
yes... it came up this morning... so now i know how to make an hour graph :-D
boelle's picture
made one for each hour.... is it normal that bars overlap?
JBecker's picture
I have the same problem........ sometimes. No idea, why.
I've noticed some " anomalies " with this method to, but not looked into why it's happening yet. see attached pic
In the pic you can see the bars appear to not start and finish at a regular time ie the centre of the bar for the 16th is before the grid line and the 17th is after the grid line and the 18th almost misses the grid line altogether.
There is also a day missing see the bar labelled Sep 16 is selected but the message in the top rh corner says the 15th, Then selecting the bar to it's right, labelled as Sep 17 the message changes to the 17th, what happened to the 16th ?
Also its unclear what period you are reporting I'm guessing the values will change depending on the time of day you run the report as you reporting 24hr periods starting now and working back is that right.
JBecker's picture
Someone else (Eric?) also reported 'shifted' bargraphs which were not centered on the day tick. I never see this, mine are always perfectly centered. But the rest is exactly as you say, Paul.
boelle's picture
hmm... i just noted the clear thing on the daily chart that the bar i have is for today and its not getting bigger
it should as tina is making homemade chicken soup... stove have been on for almost 3 hours...
so i guess its a whole day off :-/
