Help with Export to CSV function in Emoncms V8
Just upgraded to Emoncms V8 on my Pi.
If I try to download a csv file for an SQL feed it gives a file size but the file produced always contains no data and is empty.
If I try to download a csv file for a Timestore feed I get the following errors:
<br />
<b>Warning</b>:  Creating default object from empty value in <b>/var/www/emoncms/Modules/feed/engine/Timestore.php</b> on line <b>269</b><br />
<br />
<b>Notice</b>:  Undefined variable: npoints in <b>/var/www/emoncms/Modules/feed/engine/Timestore.php</b> on line <b>273</b><br />
false
This happens whether or not I try to download from emoncms.org or localhost.
Not sure where I've gone wrong.
Re: Help with Export to CSV function in Emoncms V8
I can see the there is something amiss there, not sure what it is, Il look into it.
hendersoniain's picture
OK. That would be good thanks.
Did you get anywhere with this Trystan?
