hi
a have installing v8.2.6 on a Ubuntu 14.04 LTS, following "install on Linux (via git)
and evrything seems to work without problem but when a try to creat the first user
nothing happens, the only thing a can see is a pink but empty box
any tips.
//Niclas
Re: cant register user in 8.2.6
i have the same problem. emoncms 8.2.6 installed on debian stable (not on rapsberrypi).
registering is not working here too :(
I had this problem.
I think the instructions here http://emoncms.org/site/docs/installlinux need updating.
sudo nano /etc/apache2/sites-available/000-default opens a blank file.
Searching the net I found:-
sudo nano /etc/apache2/apache2.conf
This seems to be the file where "AllowOverride None" needs to be changed.
I am no Linux expert but after changing this file I was able to register.
Ian
Ian, Are there any other files in your /etc/apache2/sites-available directory, Could the 000-default file have been moved to another file/directory with a recent apache update?
Hi Trystan
in /etc/apache2/sites-available there is 000-default.conf and default-sl.conf. but they do not contain "AllowOverride None" lines.
As I say I found /etc/apache2/apache2.conf which did contain "AllowOverride None" so I changed those and everything seems to work OK.
Ian
