Keyboard layout
Hi there!
I have created SD with copy of emonGateway downloaded from here (http://emoncms.org/site/docs/raspberrypigateway), i have booted but now i would like change to spanish keyboard layout but is impossible.
I have an USB Spanish keyboard connected to RaspberryPI and have tried:
# ipe-wr
# dpkg-reconfigure keyboard-configuration
# ipe-ro
... but at the end UK-keyboard-layout is not changed.
Any idea?
Re: Keyboard layout
Firstly I assume that "ipe-wr" is a typo and you meant "ipe-rw" :-)
Secondly I assume you have tried rebooting as the new settings mayneed to be loaded
You could try editing the keyboard settings file directly
ipe-rw
nano /etc/default/keyboard
and change the " XKBLAYOUT="gb" " to "XKBLAYOUT="es" and then run
dpkg-reconfigure -f noninteractive keyboard-configuration
invoke-rc.d keyboard-setup start
you can confirm your settings (before and) after using
debconf-show keyboard-configuration
if settings have changed successfully but keyboard hasn't it may need to reboot for new settings to load.
rmce's picture
Re: Keyboard layout
Thanks Paul,
Yes,it is a typo :)
I will try it again following your notes.
Regards.
rmce's picture
Re: Keyboard layout
Hi there!
I have followed these commands in Raspberry Pi using 2 different connected Spanish keyboards without successful results.
# ipe-rw
# nano /etc/default/keyboard  (or # dpkg-reconfigure keyboard-configuration)
# invoke-rc.d keyboard-setup start
# debconf-show keyboard-configuration (i can see changes)
# ipe-ro
# reboot
... I can see the updated values in config files but Spanish keyboard layout is not applied. It continues GB keyboard layout.
Also, I have tried changing locales (# dpkg-reconfigure locales) with same results.
At the end, I have configured eth0 interface with static IP and have connected to RaspberryPi with SSH, and in SSH client (terminal) Spanish keymap is automatically loaded !!.
Well, as workaround I am using SSH terminal but if anyone has any idea, it will be welcome!.
Regards.,
