Re: How can I get the mac address from the emon.tx
Submitted by kjlowe (not verified) on Wed, 21/03/2012 - 08:19.
If you meant the emonBase as mharizanov suggested, I find the easiest way is to give it an IP address usign DCHP. Your router should report the mac address once it's been assigned an ip.
You can also print it out serially from the emonBase. The mac address is stored here.
EmonTX doesn't have a network interface, so it doesn't have a MAC address either. Only EmonBaseRF has MAC address
