Feed inactive - kWh to kWh/d
I use Emoncms online for a few week ... all work very fine !! Thanks for your good work !
So I have installed Emoncms of my Raspberry, the install work. I have Install the emoncms application via git.
The data Input is Ok but when I configure the process kWh to kWh/d, the feed is inactive and that after several hours.
Of my account online is work but the same configuration don't work of my Rapberry.
In check with Emoncms V8.0.8 and V8.1.2, I have the same problem. Can you help me ?
gloorung's picture
Re: Feed inactive - kWh to kWh/d
Could it be because redis is not installed? The kwh-to-kwh/d operator only works if this is installed.
