Module sync and error
Hello!
When I install the Module "sync", I get the error:
/var/www/emoncms/Modules/feed/feed_model.php on line 25
Warning: Missing argument 3 for Feed::__construct(), called in /var/www/emoncms/Modules/sync/sync_controller.php on line 33 and defined in /var/www/emoncms/Modules/feed/feed_model.php on line 25
Notice: Undefined variable: redis in /var/www/emoncms/Modules/feed/feed_model.php on line 28
I want to sync down the online feeds.
Thank you!
Server: Ubuntu 13.10 x64
ecomcms: 8.1.1
ukmoose's picture
Re: Module sync and error
As per http://www.openenergymonitor.org/emon/node/4074 I don't think the sync module is compatible v8.1 yet.
unique24's picture
Ok, thank you!
