on-time in hours
Hello!
I want to log the on-time of my heating pump in hours.
The process "on-time" calculate this in seconds ... how can I display the bar chart in hours?
Thank you!
Ian Eagland's picture
Re: on-time in hours
Are you running on your own server?
If so I asked Trystan this question back in January. His answer :- (for minutes not hours)
Thats a difficult one without a modification to the input on-time processing function itself. As your running it locally I guess this could be a good option?
If you multipled this line by 1/60 that should work: https://github.com/emoncms/emoncms/blob/master/Modules/input/process_model.php#L271
All the best
Trystan
Ian
unique24's picture
Hi Ian!
Thank you! But I´m using right now the online service.
I already install emoncms on my server, but want to test first online!
