[solved] new local installation and can´t user
Hello!
local Server: Ubuntu Server 13.10 x64
I install emoncms according this documentation: http://emoncms.org/site/docs/installlinux
One Point I can´t do:
$ sudo nano /etc/apache2/sites-enabled/000-default
Change (line 7 and line 11), "AllowOverride None" to "AllowOverride All".
That is the sections and ...
I have only the file:
/etc/apache2/sites-enabled/000-default.conf:
<VirtualHost *:80>
        # The ServerName directive sets the request scheme, hostname and port that
        # the server uses to identify itself. This is used when creating
        # redirection URLs. In the context of virtual hosts, the ServerName
        # specifies what hostname must appear in the request's Host: header to
        # match this virtual host. For the default virtual host (this file) this
        # value is not decisive as it is used as a last resort host regardless.
        # However, you must set it for any further virtual host explicitly.
        #ServerName www.example.com
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www
        # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
        # error, crit, alert, emerg.
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        # For most configuration files from conf-available/, which are
        # enabled or disabled at a global level, it is possible to
        # include a line for only one particular virtual host. For example the
        # following line enables the CGI configuration for this host only
        # after it has been globally disabled with "a2disconf".
        #Include conf-available/serve-cgi-bin.conf
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
When I open the site in Chrom and want set up a user, i just get a lightred box under the form and nothing happens.
The database was created! So it can´t a mysql problem.
Need some help, thank you!
unique24's picture
Re: [solved] new local installation and can´t user
I also see that the folder "user" is not present. Would it be created automatic?
Thank you!
Here's a copy of my 000-default file, you could try using this and make a backup of your existing one?
<VirtualHost *:80>
        <Directory />
                Options FollowSymLinks
                AllowOverride All
        </Directory>
        <Directory /var/www/>
                Options Indexes FollowSymLinks MultiViews
                AllowOverride All
                Order allow,deny
                allow from all
        </Directory>
        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
        <Directory "/usr/lib/cgi-bin">
                AllowOverride None
                Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
                Order allow,deny
                Allow from all
        </Directory>
        # Possible values include: debug, info, notice, warn, error, crit,
        # alert, emerg.
        LogLevel warn
        # CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
Alternatively you may want to use the debian installer method for installing emoncms, which can be found here: http://emoncms.org/site/docs/debianinstall
unique24's picture
Hello!
Many thanks!
But in the meantime I found this:
http://blog.asiantuntijakaveri.fi/2013/11/ubuntu-1310-x64-with-emoncms.html
This also work fine!
Thank you!
